Hello,
I'm a newbies with installshieldX (and newbies in English too).
I must made an install setup with
[INSTALLDIR]folder1\filesA,filesA,filesB,filesC,....
[INSTALLDIR]folder2\ (empty)
during the installation I must show a dialog with radio buttons
I create a property CHOICE
radio button group = my property CHOICE
radio button1 : value = 1
radio button2 : value = 2
if r1, write in folder2, the files f1
if r2, write in folder2, the files f2.
what is the correct sequence to do it.
create a Organization tabs a components and feature
com1, condition CHOICE = 1
com2, condition CHOICE = 2
I made it, i create the dialog, select the property.
the installation seems good but folder2 is empty.
what must I do?
Custom installation with option
pavlacki
, Oct 11 2004 20:42
Posted 12 October 2004 - 07:51
Don't use conditions, use Control Events AddLocal and Remove respectively.
In your description you don't have any files that should install to folder 2 so it's no wonder the folder is empty.
Can you please explain which files you want to install to folder 2?
