I convert the ISWI project in the IS X.
And I have three problems:
1. I can't add a font with blanks in a name (for example "my font.ttf").
2. CustomActions (Type: "Run InstallScript code") don't work after ExecuteAction in Sequences.
They work before this stage, but I need to start some functions _after_ copying files.
3. In ISWI I registered COM servers using "Registration: Self-Register".
In the new ISX I see only one way for registration: "COM Extract at Buid: Yes".
But I get warnings "The build was unable to extract COM information from...". Because necessary files are located in different folders. Project is too large and I can't keep these files in one folder.
After installation they will be in one folder.
How I can get rid of these warnings?
I would be appreciate for your help.
Converting of ISWI project in IS X
gloom
, Jun 09 2005 12:21
Posted 10 June 2005 - 16:10
1. Not sure about this one. How are you trying to add the ttf, and what are the symptoms?
2. At the end of the Execute sequence the InstalLScript engine gets shut down. You need to re-start it or avoid using InstallScript after that point (you can use a DLL or maybe VBscript instead)
Posted 10 June 2005 - 16:12
3. Turn off "extract at build". Right click the file, select Properties, and place a check mark next to "self register"
