Hi
What is the easiest way to read a value from a file that is in the same folder as the install.exe file? It can be a folder or CD.
The problem is that I must read a specially value from a file that is located on the CD (same folder as the install file). Sometimes the CD is copied to a network and its run from there.
In Wise Installer I could use %INST% (the same folder that it’s run from) but in Windows Installer its run from a temp folder under Windows.
Pelle
Finding file/folder that program run from
Pellepop
, Apr 02 2004 14:54
Posted 05 April 2004 - 05:18
Try grabbing the SourceDir property, this by default contains the directory that the installation packaged resides in.
Also, another way to find properties like this is to run the install with verbose logging, and have a scan through the property table dump at the end of the log file.
