Hello,
I display a dialog asking for IP and MAC address. By default, the fields shall display the IP and MAC of first network device. The user can change it if the installation belongs to a different device and just "OK" if only one card is installed.
By forum search I found http://www.installsi.../en/isp_net.htm "Retrieve Local TCP/IP Address" to get the IP.
But how to get the MAC address?
Thanks in advance,
Thomas
Getting MAC Address
Th.M
, Jun 09 2008 14:52
Posted 09 June 2008 - 22:37
Make a Custom Action DLL with code based on:
http://support.microsoft.com/kb/118623
Note that this sample assumes that the NetBIOS / NetBEUI protocol is bound to the NIC.
Posted 10 June 2008 - 11:43
Just read your replay...
Thanks a lot!
Actually I had also started with the netbios approach, but stuggled with the callback function within the NCB struct.
http://msdn.microsof...897(VS.85).aspx
http://msdn.microsof...902(VS.85).aspx
How to handle CALLBACKs?
Or did I get this wrong :/
Thanks a lot!
Edited by Th.M, 10 June 2008 - 15:03.
Posted 17 June 2008 - 19:04
I would suggest using WMI, here is an example:
http://www.codeproje...throuh_WMI.aspx
It's pretty easy and straight forward. WMI is the recommended interface to get system/hardware information.
Regards,
Morteza
Regards,
Morteza
Posted 23 June 2008 - 13:08
Hi Morteza,
sry for replaying that late...
Thank you very much for that information, I'm not completely done with it, but I think it will work this way.
Thomas
