I am using IS 6.3. We can use DialogSetInfo(DLG_INFO_ALTIMAGE,SUPPORTDIR^DIALOG_BITMAP_FILENAME, TRUE) to display my own bitmap instead of the default IS image.
It seems like the panel has two frames instead of one (like in IS 5.5). DialogSetInfo can only handle the small upper right image.
Is there a standard function to replace the whole background image in that left-panel without updating the corresponding image resource from _IsUser.dll?
Welcome Dialog - left panel image
sod
, Mar 02 2006 03:19
Posted 02 March 2006 - 20:11
You need to edit the dialog resource for this.
Posted 06 March 2006 - 16:56
You would probably need to hack the resource in some InstallShield program file. But since the InstallScript engine is shared across setups this may affect other instalaltions as well. I don't recommend it.
