In Custom Setup dialog each feature displays the space requirements. I am needing to show in that space how much space is required by the installer, regardless if there is already files installed there.
What is happening is that I am upgrading from Wise to Installshield, so running the installer shows the "additional" disk space needed.
Any suggestion on how to force this to show the size of the feature?
A
Feature Disk Space
finding_this_difficult
, Jul 26 2005 17:53
Posted 26 July 2005 - 22:05
This is by design. I guess the only way around it would be a custom user interface. Note that in this case your setup will behave different from all the other msi based setups out there which might confuse your customers.
Posted 28 July 2005 - 19:27
Thanks... I just went in and added "an additional" in the CustomSetup Dialog string to hopefully clear things up a little. It really only matters for this initial setup and I really don't want to build another custom dialog, I like the wheel the way it is.
- A
- A
