Hi ,
While validation for Vista in ORCA i am getting Error 99. Its says that you can't use [WindowsVolume] property. One of the feature uses this property for installation of few files where windows is installed.
Is there any equivalent property for WindowsVolume ?
This error is not observed for XP validation suite.
Regards,
Amarjeet
ICE 99 error in ORCA
Amarjeet
, Aug 03 2009 07:48
Posted 04 August 2009 - 19:55
What's the exact error message? Do you have WindowsVolume defined in the Directory table (you shouldn't)?
Posted 05 August 2009 - 11:10
I have windowsvolume in directory table.
I am installing one of my component in [WindowsVolume]test\Data directory.
Alternately is there any way to find out WindowsVolume on destination computer.
Is thers way i can rename WindowsVolume ? and still able to install at WindowsVolume ?
I used PRIMARYVOLUMEPATH , but its not working.
Its quite unfortunate that micrsoft says you can't use WindowsVolume, as its reserved keyword.
But diplays WindowsVolume as property on MSDN help
http://msdn.microsof...817(VS.85).aspx
Amarjeet
Amarjeet
Posted 05 August 2009 - 17:34
You can't define WindowsVolume in the Directory table but maybe you can reference it. If that doesn't work, use a custom name (like MyWindowsVolume) as destination for your component, and use a custom action to set it to the value [WindowsVolume]
