I am trying to create a log file with a unique name and I want to control the location of the file. I know I can add to the MSI log file by specifying /l +v but this will cause the log file to be very large after the installation has been run more than once. There is an environment variable called %random% that I try to use. It will generate a random number but this does not seem to be recognized by msi.
A simple command like
dir > %SystemDrive%log-%random%.log correctly generates a file like C:\log-23342.log
These are the parameters I pass to msiexec and the resulting file
/l*v %SystemDrive%\log-%random%.log -> C:\log-%random%.log
/l*v %random% -> %random%
As you can see MSI expands the SystemDrive variable fine but ignore %random%
Why is this and is there any way to generate a unique file name with a known location?
MSI does not expand %random% environment variable
frede
, Apr 12 2011 08:05
Posted 18 April 2011 - 20:11
Not exactly what you are looking for, but this registry entry will create a randomly named log file in the temp folder:
[HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\Installer]
"Logging"="voicewarmup"
For more details see http://www.msifaq.com/a/1022.htm
