When I was using InstallShield Professional, I could use the OnInstalled event to run the installation of an application that was provided as a single EXE file. For example, MDAC ships as one EXE that, once run, installs MDAC.
What I would like to know is if there is a way to do the same thing under InstallShield Multi-Platform in order to launch the EXE once it is installed on disk.
Regards,
David Winter
