i write the installations for my company and recently the newest version of our installation is producing a funny window.
when a user runs an upgrade from a previous version and the upgrade requires a reboot a window appears after the "finish"/"reboot" button is clicked. the window is titled "you should not see me".
i've done a search on this phrase in Google and some other groups have come across this window as well and have seemed to have narrowed it down to a Windows Installer window.
has anyone seen this before? and how do you get rid of it?
"you should not see me" window
dtasanas
, Jun 03 2004 22:47
Posted 18 June 2004 - 15:53
i figured this out... i'm suprised no one else has come across this problem.
i talked with Microsoft on this one and found out the situation.
the "you should not see me" window is a windows app that assists in closing down programs during shutdown. if there is a process that has difficulty shutting down this window may pop up as windows tries to close it. i have noticed this happening only on win2k sp4 or XP machines.
i ran across this because i was using PackageForTheWeb to compress my install for downloading. when the user ran the PFTW self extracting executable it created a PTFW shell that persisted during the install. then... when the install calls for a reboot the shell had difficulty shutting down so the user may see the "you should not see me" window.
i solved this by not using PFTW.
Don Tasanasanta[br]Configuration/Installation Eng
