Hi there,
Here's my scenario, I'm switching back to InstallShield from Wise and I have a few questions about Registry keys.
Let's say I have a registry entry component, Comp1, that is written to HKCU and is set as the key.
Now, in another component, Comp2, I have a single, different HKCU reg entry that has NO key set.
A non-installing user initiates our app and the missing HKCU key/value triggers repair of Comp1. During the repair process, will Comp2's value be written or does the repair only fix components having keys which may be detected as missing?
HCKU Entries Not Keys?
Superfreak3
, Jan 28 2011 16:04
Posted 29 January 2011 - 17:09
It's the feature containing the component(s) that gets repaired so, if the feature contains both components, then both will be repaired.
