Silent Install
MichaelTedesco
MichaelTedesco
  • Members
  • 8 posts
Posted 14 February 2002 - 18:03
I'm executing an install with the -r command line parameter.  The Setup.iss file is not being created (I've searched the entire hard drive).
I've tried this on both Windows 98 and Windows NT.
Any help on this would be appreciated -- thanks!
Taco Bell
Taco Bell
    IS6 Expert
  • Moderators
  • 1,281 posts
Posted 14 February 2002 - 18:28
It should be created in C:\WINDOWS or C:\WINNT respectively.
Are you sure that the setup file is from InstallShield and not something based on the Windows Installer or using the PackageForTheWeb wizard?
MichaelTedesco
MichaelTedesco
  • Members
  • 8 posts
Posted 19 February 2002 - 22:22
Problem fixed:  I was building "Single Disk Image" media.  Once we built a standard setup.exe the Setup.Iss file is being created.
Taco Bell
Taco Bell
    IS6 Expert
  • Moderators
  • 1,281 posts
Posted 20 February 2002 - 00:00
Yeah, you have to use additional switches in such case, so changing to a standard setup would get around that.
