with our application we supply lots of files distributed in lots of directories. The structure is something like this (simplified):
Dynamic links: Excluding subfolder
Maharani
, Mar 06 2007 14:24
Posted 06 March 2007 - 14:24
root sub1 sub2 subsub1 subsub2 samples_english samples_german sub3 |
and so on.
After installing the tree should look like
root sub1 sub2 subsub1 subsub2 samples sub3 |
I want to have a filegroup for the english files, for the german files and for the neutral files. Therefore I need to exclude one or more complete folders. Help states that by selecting a path variable in the exclude list I could do so, just that I don't see any path variable in the combo box. I tried to exclude <PATH_TO_GERMAN_SAMPLES> or <PATH_TO_GERMAN_SAMPLES>\*.*
but this didn't help either, files are still included.
So what is the correct syntax? Or is it impossible to exclude folders in dynamic links?
I really need some approach to handle this sort of structure, developers won't provide the files in another way because they prefer me going mad instead of themselves.
And I would like to use dynamic linking as high in the hierarchy as possible because I prefer not going mad at all - this structure is bound to change quite often, and we have _several_ folders with similar structures.
As a workaround I had the idea of copying the files into a structure suitable to InstallShield mechanism (i.e. by a VBScript). I'd like to know whether there is a possibility of telling InstallShield to execute a script _before_ building the project? Usually I'm not the one actually building the complete project and experience shows that starting a VBScript before starting InstallShield is never remembered, despite all the ReadMe-Files in the setup folder.
Any hint would be greatly appreciated.
Thanks.
Rita
Posted 15 March 2007 - 21:23
Hi Rita,
Try to just put "samples_*" in the exclude list.
And then create another component(s) that would handle languages appropriately.
Regards,
RUS ULANOFF
RUS ULANOFF
