Hey guys/gals, I'm trying to change the ugly blue bitmap that appears on the left-hand side of many of the dialogs in Installshield's Developer 7.0. I went into the direct editor and discovered that the bitmap is stored in a binary table entry called NewBinary2. I replaced the existing binary data with the bitmap I created and I rebuilt the project. However, the bitmap hasn't changed, it's still the same. I opened up the resource file, _ISUser1033.rc, with Visual C and the dialog is correctly changed with my new bitmap. It's almost as if the install isn't using the update resource file. Does anyone know what I need to do to change the background bitmap? Thank you.
Dialog Bitmap
CGreg
, Feb 28 2002 23:11
Posted 01 March 2002 - 08:38
Make sure you uninstalled the previous version, and you new build has a unique package code.
Posted 01 March 2002 - 14:10
Thanks for your suggestion Stefan, unfortunately, I've tried this before. I reimage the machine I install on after every installation, thus, the previous version is way gone. What's more, I 've tried changing every Guid in the project. Thanks for your reply! :)
