I need to create 1 install disk which will allow the user to install multiple copy of the application on 1 PC. The user will select different names per install like
ApplicationNameFolder1
ApplicationNameFolder2
ApplicationNameFolder3
ApplicationNameFolder4
and so on,
However, the Installshield engine will see the prior GUID from the first installation and go directly to the maintenance screen to modify, remove, etc...
How do I override the maintenance mode and permit the user to drop multiple installs of the same applications?
Rage
How to do multiple instance install?
comicrage
, Oct 26 2004 15:40
