How can I disable a feature in the custom setup dialog box initially? The user should be able to change the install state of the feature.
The function MsiSetFeatureState in install script fails, when I try to do this. But when I use the same funciton in a VC++ dll, it works. Is there some way to make this work without using a VC++ dll?
When I use the install shield REMOVE property, it disables all the features in the custom setup dialog box.
Disable a feature - accept user input
vkj
, Oct 07 2002 12:25
Posted 07 October 2002 - 13:02
Make sure the feature's install level is above the package's INSTALLLEVEL property
Posted 08 October 2002 - 12:30
It worked when I set ADDLOCAL=ALL, along with REMOVE=<feature name>.
If you want the feature to be conditionally unchecked, you can set REMOVE="" using MsiSetProperty.
