Hi
I'm using Installshield Professional 6.2 and have to install a VB.NET application that uses Crystal reports.
I am vaguely aware that I have to install Crystal_Managed2003.msm and Crystal_regwiz2003.msm.
I just want to know if it is possible to successfully do this using my version of I.S. and if so what are the steps I would have to take.
Any help is much appreciated.
Sean
Crystal Reports in .NET
Seany
, Feb 16 2005 13:48
Posted 16 February 2005 - 20:06
Professional 6.x has no built in capabilities to install Merge Modules (.msm files). There may be a Crystal object included in your version that you can use. Otherwise you would either have to include the Crystal files separately, or get a Crystal setup.exe package, or build a simple Windows Installer setup (.msi file) that can import the MSMs and call that from your setup, or upgrade to the latest version of InstallShield.
