What I'm doing is this:
1. I created an entry in the Directory Table that has the following values:
Directory Directory_Parent DefaultDir
LogFolder TARGETDIR Log:.
2. I create an entry in the CreateFolder Table that lists "LogFolder" in the
first column and the component I want it to be created with in the other.
The install runs successfully, but the empty "Log" directory is not created. I tried having "Log" and ".:Log" instead of "Log:.", but that had the same results. The help mentioned something about having the Directory value be the same name as a property, so I created a property of the same name. Still no luck.
