I've got 2 files that I need to install depending on the OS. (ole32.dll) I've got 2 components set up with the appropriate dll in the appropriate component. I've got the component set up to install to the system directory and have the compent set to install only on version9X machines and the other for versionNT machines.
When I do my build (files Uncompressed) and I go out and look at the disk image that I built, I see only one ole32.dll. Any idea where the other one went, and how I can be assured that the right DLL is installing on the right OS?
Multiple files - different versions installed
brianw
, Jan 30 2003 17:24
Posted 30 January 2003 - 23:41
You need to specify a source location for this file. Else the two files will overwrite each other in your uncompressed disk image. Or you can use a compressed build.
