I have created two projects in InstallScript 10.5 on the same
machine, using the same compiles and environment.
One of them sould be part of another to be called silently.
From the command line the silent install runs prefectly as: setup.exe /s
It does all requiered job, but as soon as I'm trying to call it from
another project, it produces the message:
Another instance of this setup is already running.
Please wait for the other instance to finish and then try again.
I'm calling the setup.exe with LaunchAppAndWait function.
What ever I tried, i.e. calling ChangeDirectory before, create custom
_LaunchAppEx, played with all parameters of LaunchAppAndWait,
nothing seems to work.
Also I have tried DoInstall function in InstallScript 10.5,
it seems to call the regular installation
with UI (all UI custom skins corrupted though), but it does't work for
the silent installation as well.
I have tried to call silent install created with InstallScript 10.5 from
InstallShield for Windows Installer 2.0 using the same LaunchAppAndWait,
but the error is more strange:
Please go to control pannel and check your System Configuration.
Only InstallShield 6.2 project has called silent InstallScript 10.5
correctly without any problem using LaunchAppAndWait function.
Is it actially possible to run silent install for InstallScript 10.5 from
within another InstallScript 10.5?
Any idea will be greatly appretiated.
Nested silent installation is not working.
ibm
, May 13 2005 20:04
