Thanks in advance.
Passing properties to deferred CA
Bernie
, May 31 2001 21:42
Posted 31 May 2001 - 21:42
I am trying to access properties (eg _IsMaintenance or my own property) using Session.Property() inside a deferred CA, but they just coming up blank. Any ideas?
Posted 31 May 2001 - 22:29
In general you can not get at properties directly from within a deferred custom action. Hoever there is a special property called "CustomActionData"
If you set a property with the same name as your custom action then that value is the CustomActionData for your custom action.
Posted 07 June 2001 - 22:26
Depending on the kind of CA you are using, you can often define a command line to go with the action. Once the values of the properties are written into the install 'script' they will hang around until you actually execute your routine.
