Hi ,
In Installscript , while calling LaunchAppAndWait API, it returns successfull . i.e returns Zero. But while the return code from LAAW_PARAMETERS.nLaunchResult = "259". What is the reason for such conflict ?
Here the code follows:
LaunchAppAndWait( "exampl.exe", "", LAAW_OPTION_WAIT | LAAW_OPTION_HIDDEN);-----> returns 0 --- successful.
LAAW_PARAMETERS.nLaunchResult ----> returns 259.
Please reply if anyone knows. Thanks in advance
LAAW_PARAMETERS.nLaunchResult returns error code "259" .
shanmuga
, May 17 2013 11:55
Posted 17 May 2013 - 16:45
LaunchAppAndWait returning 0 means the application was successfully launched.
LAAW_PARAMETERS.nLaunchResult tells you the exit code that the launched application returned to the calling process (InstallShield). You need to check the documentation for the launched application to see what 259 means.
Posted 23 May 2018 - 11:22
I have the same result "259", but my launched application is returning a path. So I think the problem ist the conversion from number to string via NumToString function:
nRet1 = LaunchAppAndWait("my.exe", "my param", LAAW_OPTION_SHOW_HOURGLASS);
if (nRet1 = ISERR_SUCCESS) then
NumToStr(sRet1, LAAW_PARAMETERS.nLaunchResult);
SuiteLogInfo ("return: %s", sRet1);
endif;
Anyone any ideas how I get the returned path? Or is it not possible at all to get a returned string with LaunchAppAndWait?
endif;
Edited by Alibaba, 23 May 2018 - 11:23.
Posted 11 January 2019 - 13:36
Exit Code 259: STILL_ACTIVE
I also had this once -- if I remember correctly the meaning was that the process was still running and I needed to wait for it to end.
