Hi folks,
I have created a custom dialog in my Basic MSI project, but it should only be displayed if a certain feature is selected. The dialog only contains options for THAT feature.
I have included this in the UI sequence, but then it is always displayed.
I have also tried to create a custom action to do this, but when I insert that into the UI sequence, I cannot get it to be included in the "Install" sequence.
Is there any way I can show it ONLY if the associated feature has been chosen?
Any help appreciated,
Thanks...
Conditionally show dialog
BRY
, Apr 29 2002 09:37
Posted 29 April 2002 - 10:22
Including dialogs for only one special feature is no problem with the exception of a lot of work (it would be really simple if MS would have created a better way for the whole process of back and forward in the dialogs
OK, let's start:
The actions taken when clicking a button (Next, Back, ..) are defined via Events.
Let's assume you already have dialogs A and B in your sequence and you want your dialog NEW in between these to dialogs. The feature that NEW depends on shall be "MyFeature".
Before adding dialog NEW:
Event for button Next on dialog A:
Event Argument Condition
NewDialog B 1
Event for button Back on dialog B:
NewDialog A 1
After adding dialog NEW:
Events for button Next on dialog A:
NewDialog B Not ((&MyFeature=1) or (&MyFeature>=3))
NewDialog NEW (&MyFeature=1) or (&MyFeature>=3)
Event for button Next on dialog NEW:
NewDialog B 1
Event for button Back on dialog NEW:
NewDialog A 1
Events for button Back on dialog B:
NewDialog A Not ((&MyFeature=1) or (&MyFeature>=3))
The &MyFeature returns the action taken on the feature (how will it be after setup ran); the compare values mean:
1: INSTALLSTATE_ADVERTISED
2: INSTALLSTATE_ABSENT
3: INSTALLSTATE_LOCAL
4: INSTALLSTATE_SOURCE
Further info about conditions may be found by searching for "Conditional Statement Syntax" in the windows installer help (msi.chm, also delivered with ISWi or Developer).
OK, let's start:
NewDialog B 1
NewDialog A 1
NewDialog B 1
NewDialog A 1
h.teichert-ott
Posted 29 April 2002 - 15:36
Thanks a lot - this works perfectly!
Cheers,
Cheers,
Bryan Dickson
[br]Senior Software Engineer
[br]Fugro-UDI Limited
