I installed Visual Dev 2008 in addition to Visual Dev 2005.
Every time I select an object to be added to a Merge Module Holder, the Windows Installer Object comes up to configure Visual Dev 2008, even with Visual Dev 2005 run times.
I uninstalled all of Installshield X, then reinstalled, hotfixed, and added legacy merge modules - no change.
Any ideas apart from removing Visual Dev 2008 - I will need it.
Thanks...
Merge Module Selection forces Vis Dev Installer Di
haralds
, May 29 2009 04:19
Posted 29 May 2009 - 08:11
This article may help you to diagnose the problem:
Windows Installer launches unexpectedly, for no obvious reason
http://www.msifaq.com/a/1037.htm
Posted 29 May 2009 - 16:10
Thanks...
Windows is so tedious and buggy.
OS X is not perfect, but you see nothing like this there.
