Has anyone seen Error 1607 using Developer 7.x?
Error 1607
Shagginwaggon
, Nov 06 2001 23:45
Posted 23 November 2001 - 12:58
Yes it means the ISScript engine hasn't / couldn't be installed. YOu need it for the install to run properly.
Posted 26 November 2001 - 08:57
I am also facing the same problem, i know that the ISScript engine couldnt get installed.but what is the solution / workaroung. I am trying to install the setup on a fresh NT Machine with Service Pack 6 and IE5.5. Any Pointers ,hints.
Posted 26 November 2001 - 16:59
Check the Windows Installer service. Maybe you haven't it or it is corrupted. Try at first execute instmsiw.exe (it is MSi engine).
Posted 26 November 2001 - 20:31
This may or not be your problem but.....
this weekend, I have to use a Windows XP development system instead of Windows 2000. Because I was using an older version of ORCA to validate, (version 1.2?) I was getting tons of errors validating. After applying the new ORCA from the MSDN platform SDK, the errors went away.
just an idea...
tom
just an idea...
tom
