I am working on a Basic msi project where i am using scripting for creating the virtual directory, application pool etc. Where i am using
set objIISPools = CoGetObject("IIS://localhost/w3svc/AppPools", "");
for creating object.
this works fine in IIS6. But it doesn't work in IIS7 (windows 2008). It is noted that if the IIS6 compatible is installed, then it works.
I need a solution which will work for both IIS6 and IIS7 (without IIS6 compatiablity installaed). Also i need several customization that's why scripting is required.
Can't create virtual directory on IIS7
smunir
, Jun 29 2010 08:14
