Exception found when uninstall.
lis_ck2000
, Jul 08 2004 08:48
Posted 08 July 2004 - 08:48
i have written a software which has a custom action which will throw an exception when uninstalling. so i can't uninstall the software now. any one knowing how to remove that software entry from MSI Server?
Posted 08 July 2004 - 09:04
Use MSIZap from the Windows Installer SDK. http://msdn.microsof.../msizap_exe.asp
http://www.microsoft...msdk/sdkupdate/
About the poblem: this probably occurs because you have put a custom action after InstallFinalize that returns an error on uninstall (often because you try to access a file that is no longer on disk). The best approach is to avoid custom actions after InstallFinalize, and if you have to insert one disable the error checking for that custom action.
Note that error on uninstall like this is particularly bad because it prevents you from doing a major upgrade on the setup.
Posted 08 July 2004 - 14:56
Another option be to create a fixed MSI file, and install it as Minor Update on top of the buggy MSI. Then you should be able to uninstall.
Posted 09 July 2004 - 02:31
You could also manually edit the stored msi file on the computer and condition our or remove your code that is causing the uninstall to stop.
Posted 09 July 2004 - 02:46
Poor me, the problem is i currently don't have the MSI with me so i don't know the product code or others. is there any place or tool i can use to view detail information of the software installed in my system?
Posted 09 July 2004 - 02:48
According to Luke saying, where can i find the MSI file? i remember once i saw a directory called c:\windows\installer or c:\winnt\installer, but i can't it now. by the way, where does the windows installer keeps it installed msi?
Posted 09 July 2004 - 05:36
Well, you certainly have a few options to choose from now
, quick summary for you:
Once in this folder you will see a number of MSI files with strange names. These are random names assigned for your MSI's during installation. Select the first MSI, make sure the Windows Explorer status bar is visible and look there what the MSI's internal name is. Keep moving down the list until you find your msi. Open it, modify it and then try the uninstall (make a backup!). If this fails use MSIZap.
- 1 - The minor upgrade solution is the best if you have setups already deployed to customers. You fix the upgrade and the problem is gone.
- 2 - The MSIZap suggestion will work even if you don't know the product code for the application installed, all you need to know is the name of the application you want to get rid of plus downloading the tool. Use if you don't have customers with the app installed
- 3 - The suggestion to manually edit the installed application is best if you don't want to download the tool, and have Installshield or Orca installed so you can edit the file
Edited by Glytzhkof, 09 July 2004 - 05:47.
Posted 09 July 2004 - 07:03
Note that MsiZap will not uninstall the package, i.e. all files, registry entries etc. will be left behind.
