I want to use an EXE in my installer. Problem is, the EXE uses several DLLs and some INI files and those files are Language and OS dependent. I used to use IS PRO and this seems to be no problem since the Setup Files takes care of these files that are used exclusively by the IS program before transfer of files.
But now, since I cannot see any trace of Setup Files in IS PRO-WIS Ed, I opt to use a CA instead. Problem is I dont know how can I link my EXE (and all its dependecies!) and use it in my CA? I was thinking to just access a separate directory in the setup and then when I build the release, I will have to manually copy that directory so that when I run my setup it can find the said EXE. But its not so nice, eh? I do hope that you can give me ideas on how can I implement this.
Thanks in advance!
