Hi all
I'm trying to launch the DirectX 8.1 setup via a custom action, which I am using MsiDoAction to launch (not sure so far that this is the best way to do this). It seems to work OK except that if the user chooses 'NO' in the initial DirectX install dialog (i.e not to install), I get an error message. I checked the error code and it appears to be a fatal error (1603). Clearly I'm doing something wrong. If I run the DirectX set up independently it's fine (as you might expect).
Any ideas?
Ian
Installing DirectX 8.1 via a custom action
iank
, Mar 05 2002 18:00
Posted 06 March 2002 - 12:13
Make the custom action to ignore the return code. Windows Installer accepts only some pre definied values as result from an exe launched in a custom action, everything else will be treated as fatal error.
Posted 07 March 2002 - 10:48
Thanks for the help. I solved this through creating a seperate application that installs directx 8.1 and then launching that. I've created another issue though. I now have a console window appearing that I'd like to get rid of. Ho hum.
Ian
Ian
