I've got an installer thats going into 10 different langauges. Main language is English.
Some dialogs get different language dialogs added automatically which is great, however lets say I install in Swedish. If I decide to cancel the install it seems it calls the SdSetupCompleteError - however it gives an error
In function 'SdSetupCompleteError'
Unable to create dialog
if I run in english and do the same, it reaches the dialog with no problem
I looked at the dialogs option, no multi language dialogs get added to SdSetupCompleteError - if I right click and hit 'edit' nothing happens. Seems there is a problem with this dialog?
Multi Language dialog error
doubli
, Mar 11 2003 20:37
Posted 11 March 2003 - 21:10
Just to show you whats in my installscript file, incase this is the cause of the problem?
// FUNCTION: OnFirstUIAfter
// EVENT: FirstUIAfter event is sent after file transfer, when installation
// is run for the first time on given machine. In this event handler
// installation usually displays UI that will inform end user that
// installation has been completed successfully.
function OnFirstUIAfter()
STRING szTitle, szMsg1, szMsg2, szOption1, szOption2;
NUMBER bOpt1, bOpt2;
begin
Disable(STATUSEX);
bOpt1 = FALSE;
bOpt2 = FALSE;
szMsg1 = SdLoadString(IFX_SDFINISH_MSG1);
SdFinishEx(szTitle, szMsg1, szMsg2, szOption1, szOption2, bOpt1, bOpt2);
end;
begin
Disable(STATUSEX);
bOpt1 = FALSE;
bOpt2 = FALSE;
end;
Posted 25 March 2003 - 11:12
I've basically got the same or similar problem. The error message is the same. Attempting to edit the dialogs does show a dialog entry for each language (5), but the texts in the dialog are not always in the correct languages: it looks like the translation is missing so the text is in english.
Running the setup built with having just right clicked the dialog and specifying 'Edit...' without doing any other changes works fine apart from the texts being in the wrong language in the SdDialogCompleteError.
