I have a setup that launches a configuration utility (an executable available on CD), thru a CA. I want to hide the MSI window when this CA executes. For this i need the handle of the MSI window. How can i get this handle?
Hiding MSI installer window.
antyagi
, Nov 09 2005 13:35
6 replies to this topic
Posted 09 November 2005 - 14:19
Did you try using the funcion Disable(BACKGROUND) from InstallScript?
Posted 29 November 2005 - 13:09
In InstallScript i could have used GetWindowHandle func.
I do not want to use InstallScript at all.
Is there any way to get the handle of the window of installer?
ankur tyagi
Posted 30 November 2005 - 09:12
If you can do it from InstallScript it should also work from a DLL written in C.
Posted 30 November 2005 - 12:37
'GetWindowHandle' is an InstallScript func, it returns "handle of the main window of the installation".
What i am doing:
1. Save the output of GetWindowHandle func to a property, say WINDOW_HANDLE.
2. In dll convert the value of WINDOW_HANDLE to type "HWND'.
3. Use it as handle to installer window.
Problem (explained in more detail):
1. I do not want to include even a single line of InstallScript in my setup.
2. When InstallScript is not available GetWindowHandle func is also unavailable.
How to get the handle of window now ??
What i am doing:
ankur tyagi
Posted 02 December 2005 - 17:50
Sorry for the misunderstanding. I don't think the GetWindowHandle function will work in a Basic MSI project (from a InstallScript CA), only in InstallScript MSI and pure InstallScript. Not sure if there's a documented way (like a property) to get the MSI window handle. You may need to iterate through all winodws and compare the title.
Posted 15 December 2005 - 17:26
I confirm what Stefan says. Once, i also needed the handle of the MSI window, and I didn't find another way than to use the title to find the handle of the window.
Warning : don't try to do anything funnier than hiding. Especially, changing the style of a control like a list in the window is impossible.
