HI All
I am using Basic MSI Project of IS 7.04.
I am having a problem in continueing my setup after reboot during UNInstall.
Here the scenario.
While uninstalling my app there is a chance of having a process still running even though the file corresponding to that process is removed.Due to this the folder containing the file is not getting removed(this happens randomly). So I figured out if I reboot the machine at the end of uninstallation the process would go away from the memory and then I can do the delete of FOlders explicetly.
Can anyone help me or guide me? All I have to do is to delete folder after reboot.
I am trying to achive two these things and used all related KB article and mix and match combinations.
1) how do I schedule a reboot for uninstall condition,
2) how to delete folder if exists after reboot.
Thanks in advance for your suggestions and advices.
Ranjit
Continue setup after reboot
ranjit
, May 12 2003 17:22
Posted 13 May 2003 - 11:52
Hi Ranjit,
its probably a small attempt to help you and refers only the second part of your question. You can register programs to run once after a reboot and a user logon by a special registry key entry.
For Windows NT 4.0, Windows 2000, Windows XP you could use:
This approach is documented under:
http://msdn.microsof...gistry_keys.asp
By default, the value entry of a RunOnce key is deleted before the program is run.
Maybe someone has a better and MSI compliant solution.
Raimund
| HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce |
Raimund
Posted 13 May 2003 - 15:43
HI,
I attempted that approach , but did not help me much. I need to run the installer after reboot and check to see if the folders exsits or not. Any ways there may be a design change and hopefully we may not encounter this problem.
Apreciate your suggestion.
Thank you
Ranjit
Thank you
Ranjit
