Hello to All!
I can't find the option, to be able to make a debug on this installshield.
Can you please give me some direction how can I debug, becouse the only options that I see are: compile, build and run .
I'm a beginner for this installshield, so sorry if my topic seems to be very trivial.
Debug in InstallShield X
nelly
, Feb 14 2005 16:23
Posted 16 February 2005 - 08:12
in the Build menu there is also a command Debug. Is this command disabled? Or what happens if you press it?
Posted 17 February 2005 - 09:11
My build menu contains:
Build
Stop Build
Compile
Run
That's it, no more options. Can you help me?
Build
Stop Build
Compile
Run
Posted 17 February 2005 - 12:02
Which exact version of InstallShield are you using? (see the About dialog)
Which project type are you using? (see the title bar of the IDE window)
Posted 17 February 2005 - 14:47
I use Installshield X Universal Primier (EVALUATION)
Universal Installer Project
Posted 17 February 2005 - 20:04
I'm not very familiar with the Universal (Java-based cross-platform) project type. But I don't think it uses a script and I guess thereforte doesn't have a debugger. Debugging is available for InstallScript projects (you posted in the InstallScript forum) and in Windows Installer (MSI) projects.
