I have to update a .INI file that does not use square brackets [] around the section names. Instead, the .INI file has less than, greater than or angle brackets <>.
The built-in initialization file functions like WriteProfString, only recognize the square brackets [].
Is there a way to change the WriteProfString to recognize the angle brackets <>?
Is there InstallScript code for the WriteProfString and other initialization file functions?
INI file uses angle brackets <>
nnjcsc
, Mar 11 2008 17:28
Posted 12 March 2008 - 15:15
No. InstallShield uses the corresponding Windows API which only supports the Windows INI format, i.e. only square brackets. Yur file is not a Windows INI file, it only "happens to use the same .ini extension". So you'll have to use general text file editiong functions.
Posted 17 March 2008 - 21:21
Thanks. I resolved it. Here is how I had to do it. I had to update a number of values in an INI file that had angle brackets <> around the section. I had to find the section using FileGrep, then restart the FileGrep again for the next value. So I had to repeat the FileGrep with the RESTART followed by a FileGrep with a CONTINUE. Hope this helps someone else one day.
//Find and replace Server
szSearchStr = "Server"; // value I'm looking to change.
szInsertLine = " Server = "+svValueIwantToChange;
szSectionName = "SECTION_WITH_ANGLE_BRACKETS";
FileGrep (szFileName , szSectionName , svReturnLine , nvLineNumber , RESTART );
if FileGrep (szFileName , szSearchStr , svReturnLine , nvLineNumber , CONTINUE ) = 0 then
FileInsertLine ( szFileName , szInsertLine , nvLineNumber , REPLACE );
else
put error messsage/logging here......
endif;
else
endif;
