How is the Uninstall program or procedure created? It is not working correctly at all.
If a user tries to uninstall the program using the Control Panel, the program remains after the uninstall wizard is run.
Uninstall program
P.J.
, Mar 23 2007 23:17
Posted 24 March 2007 - 17:52
It's using your script. There are if conditional statements in your INstallScript code which get executed eiteher during install or uninstall. In addition, during installation a list of installed files etc. is created which is used during uninstall.
You could temporarily remove all your code from setup.rul so that the default code is used. Then uninstall should work again. Then you need to find out which part of your code breaks the uninstall.
Posted 29 March 2007 - 00:47
| QUOTE (Stefan Krueger @ 2007-03-24 17:52) |
| It's using your script. There are if conditional statements in your INstallScript code which get executed eiteher during install or uninstall. In addition, during installation a list of installed files etc. is created which is used during uninstall. You could temporarily remove all your code from setup.rul so that the default code is used. Then uninstall should work again. Then you need to find out which part of your code breaks the uninstall. |
where do I find these files and how to I change and study the script?
Posted 03 April 2007 - 01:31
Did you create the setup? In this case you should have the script code.
