Hello all,
when I'm doing a Major Upgrade a single file does not properly install. Setup deletes the older file but does not copy a new one. I could not find any info regarding this failure in the log file.
The problem may be that the file to be replaced has always a newer time stamp than the updated file, because it is a temporary work file which is saved every five minutes.
Doing an update on a temp file which has a older time stamp, the file is replaced properly.
Thanks for your help,
Jan
File missing after Major Upgrade
Jan_Weber
, Jun 26 2002 12:23
