Hello,
does someone has already merged the SecureCustomProperties property?
I'm manipulating the MSM file by ORCA, therefore:
Do I have to declare the property like:
SecureCustomProperties.{guid} {propertyname}.{guid}
If I declare the property only with:
SecureCustomProperties ...
the already declared property SecureCustomProperties in the MSI file will be overwritten by the SecureCustomProperties of the MSM file.
Thanks in advance!
Johannes
MSM and SecureCustomProperties
Johannes John
, Dec 22 2006 18:01
Posted 23 December 2006 - 11:49
I don't think this is possible. You would have to add your properties in the main setup.
I haven't tested this, but a type 51 custom action (set a property) in your merge module might be able to append to the SecureCustomProperties property.
Posted 13 May 2008 - 16:21
Has anyone ever figured out how to handle this?
I've tried it with a type 51 CA with no luck. It appears to set the SecureCustomProperties with the correct properties but the server side still reports the appended properties as disallowed.
