I need to install VBA6.2 files with my application's install program. I am doing it by installing from Redistributable files method (Using vba6.msi) instead of using Merge Modules. I am calling this msi file using custom action at the end of my application's install process. Installation works fine.
The problem is, if user has Office installed on the PC before installing our application and he uninstalls Office afterwards, VBA also gets uninstalled. This causes repair of our application when user starts our application, which repairs by installing VBA again and everything works again fine.
But in principle this should not happen. VBA should not get uninstalled while uninstalling Office, as my application is using it.
What could be the reason ? Your views will be great help to me.
Thanks.,
Devang.
