Hi All,
I'd like to use a property of a radiobutton group let's say _IsMaintenance into a condition field of a custom action like :
_IsMaintenance = "Remove" where Remove is the value of _IsMaintenance property when I select a radio button from the group ,for ex.Remove,so the CA to be executed only in the case I select Remove radio button.I checked with the debugger the value of _IsMaintenance in this case and is a correct value ,but the condition is never TRUE so the CA is never executed.
This happens whenever I try to use a property of radio buttons doesn't metter from what kind of dialog.
Is there a bug or I don't do proper things?
Thanks a lot,
dumitru olteanu
radiobutton group property
dolteanu
, Mar 21 2002 11:10
Posted 21 March 2002 - 14:51
_IsMaintenance is a private property (because it includes lower case characters). Therefore it's value is only availabvle in the UI sequence, but not in the execute sequence. Is your CA in the execute sequence?
Posted 21 March 2002 - 16:27
Yes ,my CA is in execute sequences but I tried to change in uppercase(_ISMAINTENANCE),I constructed again the radiobutton group but with the same result .
dumitru olteanu
dumitru olteanu
