Hi
I have an install with two Setup Types; Setup1 and Setup2
I have 3 Features, F1, F2 and F3
F1 needs to be installed for both Setup1 and Setup2.
F2 needs to be installed for Setup 1
F3 needs to be installed for Setup 2
Im ok with Setup 1 as i set the project install level to 100 and the feature install level to 100 for F1 and F2. Install level is 101 for F3. So if i select Setup1 only F1 and F2 get installed which is correct.
When I select Setup2 I set the INSTALLLEVEL=200 using a condition on the Next button.
So this will install all 3 Features but I don't want Feature F2.
To stop F2 being installed when I select Setup2 I thought I could just have a Feature Condition in Feature F1 as follows:
Level: 201 _IsSetupTypeMin="Setup2"
but this doesnt work. I've also tried the Condition Level201: INSTALLLEVEL>100 but that also does not work.
Shouldn't these set the install level of the feature to be 201 and stop it being installed as the project level is 200?
Can anyone tell me how to solve this?
