"Error 1406. Could not write value Folders to key Software\Microsoft\Windows\CurrentVersion\Installer\InProgress. Verify that you have sufficient access to that key, or contact you support personnel."
I read in a newsgroup somewhere that the Win98 registry is smaller than that of NT and 2000 and so there is not enough space to register the installation directories, could this be the case???? I hoping that it is not, how on earth could I evercome this problem other than ripping a load of directories out of my project.
The point at which the install failed, I checked registry and the InProgress key is not there.
I also checked my .msi in ORCA there are 486 entries in the directory table, about 200 of which seem to be ISWI generated DIR01-DIR200.....the values do look as though they are locations to my project files.
I do have sufficient privilages to access the registry as I have tried as the Administrator, User with full access, etc.
Any ideas, I cant even debug it, as it just fails after the UI sequence. Ive got a tight deadline on this one, and any help would be seriously appreciated.
Thanks In Advance.
Dave
(Edited by Dave I at 1:26 pm on Aug. 18, 2001)
