I was told that I might have the need to create this demol in Japanese and Korean as well as English.
Would getting the Langauge Pack - East work with DemoShield 7.0x?
Posted 27 February 2002 - 18:15
Posted 27 February 2002 - 19:53
InstallShield Developer is a setup authoring tool that generates Windows Installer based setup programs. Using the langauge pack in your hyperlink will enable to you show end user dialogs inJapanese, Korean and several other languages. All the default dialogs and error messages are already translated for you. If you modify texts or add texts you would have to translate them yourself.
DemoShield is a multi media authoring tool that can be used to create CD autorun applications (that can in turn launch your setup program), create slide shows of your product, etc. You use a graphic program to design the screens. Since the everything the end user sees is created by you (graphics, product descriptions, ...) there's no use for language packs (there are no standard texts with standard translations).
