I've done a setup capture of Realplayer in which I need to change some registry permissions. If I do the initial snapshot, install the application, fire up regedit and change the keys, then complete the process.
The permission chnage doesn't go through though. Next time I open regedit and go to that it it says the order is incorrect and resets to default permissions.
How can I change the permissions?
Registry permissions
Colin Parker
, Feb 08 2005 11:05
Posted 09 February 2005 - 15:16
Look at the LockPermissions table in the .msi file (which tool are you using?)
Posted 08 August 2008 - 22:26
I'm not quite sure how to use this table. What if I want everybody to have total access on a certain key? What values would I enter on this table?
Thanks!
Thanks!
Posted 10 August 2008 - 21:14
"Everyone" and 268435456 (GENERIC_ALL)
Posted 11 August 2008 - 16:53
Thank you for the reply.
I've added the parameters per your suggestion. When I run the setup I receive Error 1609, not a valid user or group. I'm using [%USERDOMAIN] for the domain name per the help file in the LockPermissions table. I'm not sure where to go from here although my guess is the Domain is wrong.
Posted 12 August 2008 - 19:38
Nevermind. I read carefully and saw to leave the Domain field empty. It works now.
