'm a totally newbie when it comes to InstallShield. I'm scheduled to go to training in February and the books are ordered. I'm reading through the built-in functions section in the help file and I came across the AskYesNo function. I copied the example code they had in to the InstallScript section of InstallShield right below #include "ifx.h". When I compile the script I don't get the Yes Or No box. Can someone please tell me what I am doing wrong? Here is the whole script.
// File Name: Setup.rul
// Description: Blank setup main script file
// Comments: Blank setup is an empty setup project. If you want to
// create a new project via. step-by step instructions use the
// Project Assistant.
// Included header files ----------------------------------------------------
#include "ifx.h"
* InstallShield Example Script
* Demonstrates the AskYesNo function.
* This script asks the user whether or not to display the
* ReadMe file. If yes, the script launches the Windows
* Notepad to open a ReadMe file.
* Note: Before running this script, set the preprocessor
* constants so that they reference the fully qualified
* names of the Windows Notepad executable and a valid
* text file on the target system.
#define PROGRAM "C:\\Windows\\Notepad.exe"
#define PARAM "C:\\Windows\\Readme.txt"
// Include Ifx.h for built-in InstallScript function prototypes.
#include "Ifx.h"
export prototype ExFn_AskYesNo(HWND);
function ExFn_AskYesNo(hMSI)
begin
// Display the AskYesNo dialog box. The default is set to Yes.
if (AskYesNo("Installation complete. Would you like to read the Readme " +
"file now?", YES) = YES) then
LaunchApp(PROGRAM, PARAM);
endif;
end;
Newbie Question
viponly
, Nov 17 2005 18:47
Posted 17 November 2005 - 22:57
You need to call your function in one of the event handlers.
