I'm new to InstallShield, so I may be missing something obvious, but others who've had experience can't solve my problem either:
I have tried to use CallDLLFx to call a DLL function which is visible (I've used the Dependency Walker in VC++), but I keep getting -1 return codes.
I have tried altering the destination function, with Exclaims and MessageBoxes, but it isn't even being called. I've also tried moving the DLL to C:\, but with no luck. The problem is happening in a number of places with the same DLL, which has worked before perfectly.
Any ideas??? I'm desperate!
Thanks in advance
CallDLLFx Problems
Jaybe38
, Mar 12 2002 21:24
Posted 13 March 2002 - 17:13
Make sure that all of the required dll's are available on the machine as well. For your dll to work, you may also required a couple others.
Why are you using CallDLLFx and not just prototyping the function?
Anthony
Anthony
Product Availability Developer
Avantis
Invensys Process Systems
Using InstallShield Developer 7.04 - Basic Project
Avantis
