I have an existing setup programme which cater for only one application.
Now I need to create it to support different presentations of the same application (customizing the front end, keep the backend as it is)
How do I do that? do I have to create seperate setup programmes for each presentation?
Is it possible to use a logic to switch between each presentation at the time the setup builds?
regards,
thusitha
Same setup for mutilple instances
thusithakumara
, Jan 17 2005 12:06
Posted 18 January 2005 - 09:21
Depending on your InstallShield version support for multi-instance installs may be included (I think it started with Professional 7).
In DevStudio 9 the setting is General Information > Project Properties > Maintenance Experience > Multi-Instance.
I don't remember where this setting was in previous versions.
