Hi
I am trying to use API calls from a visual basic program to retrieve information from the MSI databse, without much sucsess. The code is as follows:
Function GetMSISize(ByVal strPath As String) As Integer
Dim intViewHandle As Integer
Dim intDBHandle As Integer
Dim intRecHandle As Integer
Dim intRC As Integer
Dim strSQL As String
Dim intSize As Integer
strSQL = "SELECT FileSize FROM File"
intRC = MsiOpenDatabase(strPath, CStr(MSIDBOPEN_READONLY), intDBHandle)
intRC = MsiDatabaseOpenView(intDBHandle, strSQL, intViewHandle)
intRC = MsiViewExecute(intViewHandle, 0)
intRC = MsiViewFetch(intViewHandle, intRecHandle)
Do While MsiViewFetch(intViewHandle, intRecHandle) = ERROR_SUCCESS
intSize = intSize + MsiRecordGetInteger(intRecHandle, 1)
intRC = MsiCloseHandle(intRecHandle)
Loop
intRC = MsiCloseHandle(intViewHandle)
intRC = MsiCloseHandle(intDBHandle)
GetMSISize = intSize / 1048576
End Function
It seems to run fine until the MSIViewExecute function which returns ERROR_INVALID_HANDLE. I'm sertain that I have declared all the API functions and constants correctly. Does anyone have any ideas?
Julia
API calls to MSI file from VB.NET
JFaulkner
, May 13 2002 11:48
Posted 13 May 2002 - 12:50
Haven't actually tried to do anything like this... yet... but I have a thought.
Could you use the Windows Installer automation objects?
Project->Add a Reference, COM Tab, check Microsoft Windows Installer Object Library. Then you should be able to create an Installer object and a Database from that, etc.
The API actually seems to be developed FROM the COM object for use in C++; in anything else the COM object is usually much easier.
Paul Riley (Vector Networks), InstallShield User.
