HI,
I have a standred project(7.0x) and a coustom dialog.I have an edit boxs similar to IP address, all I wanted to konw is , how to verify if the user is entering only numbers instead of text.
thanks in advance for you time and thoughts
ranjit
Validate for Number Input only
ranjit
, Jul 24 2002 00:15
Posted 30 July 2002 - 21:30
You can set a property to handle a text from your edit box, like IPADDRESS, then create a custom action to validate this property. It may be C code or VB script which should validate this string (e.g. to compare ASCII code of characteristics). This validation custom action will set a VALIDATE property as "Yes", if this string was entered correctly, or "No" otherwise. After this you can use the VALIDATE property as a condition on the Next button, or whatever you want.
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
Posted 31 July 2002 - 08:58
You may find the masked edit control useful here.
A mask such as "<###.###.###.###>" might be ok for an IP Addresss.
You still need a CA to verify that the IP Address is valid. You may also need routines to convert the address between canonical forms.
Ian Blake
(Currently Unemployed)
