Hi All,
I am kind of new to creating a basic msi from scratch.
I have worked on installscript based msis but I just used to maintain the code. So my experience in coming up with a new basic msi is suspect.
What I would like to know is how can I have a simple msi which can be used to install a war file and add a couple of environment variables.
I have succeeded in creating a setup, but I have few concerns about the UI.
How can I customise the UI?
Regards,
Vishal
How to create a basic msi to install a war file?
vishalv
, Apr 19 2007 13:54
Posted 19 April 2007 - 18:22
In general you can customize the UI in the dialog editor. What do you need to change?
Posted 04 June 2007 - 09:35
Hi Stefan,
Thanks a lot.
I was able to create a basic msi script and I was able to create a crude setup. Thanks for the reply.
However I have few questions:
1. how do I detect whether a product is installed or not ?
I know that we can use the reg locator to do so but how do I change the condition after the product is detected. I have set the initial value to 0 in the property table. How and where do I change the value once the product is detected?
2. How can I change the install path for only a single component once a product is detected? My requirement is to deploy the war file if Tomcat is installed.
Regards,
Vishal
Thanks a lot.
Regards,
Vishal
Posted 04 June 2007 - 10:48
1. Your RegLocaltor search will set a property (which you defined in the AppSearch table - or all in the System Search view). You can use that property in a conditional statement.
2. Use a separate directory property (Directory table entry) for that component. USe a custom action of type "set a directory" (after CostFinalize) to change this directory property depending on the property that was set by your registry search.
