Well i'm trying to install a program called LabView at work, this has to be done in the background so i'm using /qn for NO dialog boxes, and putting USERNAME= COMPANYNAME= SERIALNUMBER= in the command line also.
So far everything is going well, but i need to stop the program from rebooting when finished installing, how do i do that?
This is my first day, playing with *.msi files and this site has been very helpful, so thx very much.
DaVinci
Installing from .msi without restart
DaVinci
, Dec 17 2002 14:34
Posted 18 December 2002 - 13:35
there is a REBOOT public property that you might want to try. either embed it in the msi/mst or specifiy at the command-line...
REBOOT=ReallySuppress worked for us. there is also the Force and Suppress values that will offer limited suppression...
Posted 18 December 2002 - 13:58
Thx alot, i will try them and tell you if they worked for me or not.
I had no luck with
REBOOTYESNO=NO
which i found on the net.
DaVinci
ADDED: It worked like a charm, so thx alot for the tip, i did stumple upon the very same commands in the MS knowledge center.
I had no luck with
REBOOTYESNO=NO
DaVinci
